Hello Guest it is October 25, 2026, 12:21:10 PM
Author Topic: Mach3 using Galil servo card  (Read 45521 times)
Offline kcrouch
  •  193 193
  • In way too deep!!!
Re: Mach3 using Galil servo card
« Reply #10 on: March 19, 2008, 11:16:33 AM »
Just want to add my input here. I am also using a Galil 1700 board. I have unchecked both boxes under "motor options" in the Galil plugin. My DRO's now display the actual axis position as returned by the encoders. If I power down the axis and move the table, the DRO's display the actual movement of the unpowered table. Might be worth trying on Your system. Are any of You using a pendant for edge locating? If so which one. I was looking at Peter Homanns pendant, but am not sure about it working with Galil controllers. Any input?
Kenny
Having way too much fun! Something must surely be wrong.
« Reply #11 on: March 19, 2008, 06:39:25 PM »
Do any of you guys use probes or tool setters?  I just bought a Galil 2160 control and amp-19540 for the mill I am setting up.  I posted in the plugin thread but I think I may be the only person reading it.
« Reply #12 on: March 20, 2008, 05:54:47 PM »
Thanks Jeff and Dmrrell,
Jeff I'd like to see the schematic when you are done with it.
Thanks DM, good to know my micro-switch implementation (I use ramps too) willl hold out. The voice of experience is awsome!
--Scott
--Scott
Offline kcrouch
  •  193 193
« Reply #13 on: March 20, 2008, 06:04:45 PM »
At present, the Galil plugin doesn't support probing. I need it too and am trying to get it working. The Galil plug-in is still in its infancy and needs some work to implement features that the stepper guys currently enjoy. But, the Galil controller is my way of choice.
Kenny
« Reply #14 on: March 20, 2008, 06:06:10 PM »
I have a similar quesiont about pendant interface.
The pendent I'm using is the one that came from Camsoft (http://www.cnccontrols.com/hhpendant.asp) -- hoping to use it with Mach 3.
It's rotary encoder is wired directly into the aux-encoder (4th axis I think) input on the Galil.  I had to write a lot of script to get it to work properly with the old controller S/W.
When I get the pendant working with Mach 3 I'll post any VB script (or whatever extra code).  During my conversion I'm re-documenting (lost the original) my wiring to the I/O lines and will post it if anyone is interested.
Anyway right now; The e-stop button is wired to the e-stop I/O line on the Galil (duh) and the buttons and lights are wired to various other I/O lines.  As for the controller -- I paid *way* too much for it, especially when you look at the pendents on ebay right now, that I think they are pretty nice. Although with the pendant I have I was able to get away with no face panel at the user console, but am now thinking that's not such a good idea because you might not be near the pendant when you need it.  Or if the thing gets tangled up somewhere you are out of luck until you reach a mouse or touch screen...
--Scott
« Reply #15 on: March 20, 2008, 06:09:58 PM »
Could probe and tool setting be handled by custom script in Mach 3?  I'm too new to Mach 3 to know what's possible here.
--Scott
« Reply #16 on: March 20, 2008, 06:55:31 PM »
I was thinking of getting a hand held too but it doesn't make any sense for me to get one that hooks up to mach.  It would be kind of silly to get a hand held that hooks up to my laptop but one that plugs straight into the galil control so I can do simple stuff without even bothering with mach--now that's intriguing.  I don't know if you have a stand alone or not but QSI makes some terminals that work with the ethernet galil controllers and the qterm-g55 hand held looks affordable.
http://www.qsicorp.com/product/industrial/qterm-g55.php
If anyone is using one of these and has some feedback on it I'd be very interested to hear it.
« Reply #17 on: March 21, 2008, 02:05:45 AM »
off topic -- Now thoses hand-held terminals are interesting!  I've gathered some parts to (some day) make something like those, on the cheap -- now I don't believe I could finish my LCD pendant for less $$$.  Well worth looking at IMHO.
--Scott
« Reply #18 on: July 27, 2008, 06:13:08 PM »
Does the Galil Plugin reset the PID values?
I tuned my servos using the WSDK, which stores the PID values on the card (I don't think it's an actual "burn") when it's done.  If I exit the WSDK, and run in again, the PID values that are shown before I run any tests are the same as before.  No change = "good".  It's always been "set and forget" before this.
If I run Mach3 + Galil plugin, then exit, not even run a job, then run WSDK or DMCTerminal program to query the PID values... they are reset back to the system default.  Changed PID values = "bad", "very bad".
It appears that Galil plugin is doing some kind of reset or master reset of the card?  A regular reset shouldn't cause a problem because the values are supposed to be stored in flash memory.
--Scott
--Scott
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #19 on: July 27, 2008, 06:20:57 PM »
The Galil plug-in does not change the pid values in teh Galil card. After tuning your system, or making nay other setting changes to the bard itself you must 'burn' issue a BN command to the card so the settings are saved in the eeprom. Any changes not burned are lost on a card reset (soft reset that mach does or power cycle.)
Happy machining , Jeff Birt
