Hello Guest it is November 18, 2026, 01:04:06 PM
Author Topic: Problem with ESS C25XP, Noice?  (Read 50125 times)
« on: January 16, 2023, 10:27:34 AM »
I´m in the process of changing a crap-chineese-controller to a ESS and i'm stuck with this problem.
It´s a ATC-spindle and I have outputs for tool clamping and dust shoe.
Everything is just fine until I hit clamp/unclamp tool. When I hit it the tool unclamps, all is good. But when I hit it again to deactivate the pneumatic valve. I get a flash on the limit switch pins, and the limit switch is triggerd.
Check the video. https://youtube.com/shorts/gOlkb_KtOFg?feature=share
Any suggestions on what this could be and how to fix it?
Re: Problem with ESS C25XP, Noice?
« Reply #1 on: January 23, 2023, 05:48:51 PM »
what is the clamping mechanism? If it has a coil then it will have inductance. When you turn the current off to a coil/inductance there will
be a very VERY large voltage spike.....unless you have a 'catch diode'. Do you have one?. If not (and it is a coil you are switching) stop right now and fit
a catch diode or you risk blowing up your breakout board but worse still your ESS.
Do not foll around with switching currents in inductances......the voltage spikes blow s*********t all over the place.
