Hello Guest it is October 22, 2026, 04:26:30 PM
Author Topic: Working With SoftMax Limits  (Read 6994 times)
« on: January 02, 2023, 05:36:45 PM »
I am trying to cut channels in my CNC spoilboard to install T-Slots. I did not expect this to be difficult but have wasted more time than I care to admit trying to make it work. I keep getting stopped with an error message "X axis commanded over SoftMax". I am using Aspire to generate the toolpath and I have probably tried 10 different approaches to resolve this without success. My spoilboard is 61" wide, but I need to travel farther than the width so I can cut a clean channel. The machine can do it, but the software will not allow it. I have to believe there is a simple solution for this, but I am an admitted newbie and have yet to figure this out. I only have one T-Slot channel in the file figuring I can easily duplicate it once it is running correctly.
FYI;
Aspire version 11.016
AVID Post Processor 3.0
Router AVID Pro 60120
Re: Working With SoftMax Limits
« Reply #1 on: January 02, 2023, 07:20:20 PM »
what so hard? change on controler only for the job then re
Offline Bill_O
  •  615 615
« Reply #2 on: January 03, 2023, 07:53:31 AM »
KCA,
Go to Configure then Control.
Go to the Homing/Softlimits tab.
Turn off Soft Enable.
Bill
« Reply #3 on: January 05, 2023, 01:23:35 PM »
Thank you for your help! Your solution was what I was looking for. I tried it and successfully cut all the channels I needed.
