Hello Guest it is October 22, 2026, 03:42:01 PM
Author Topic: Help Strange Macro Problem seems to load at startup  (Read 6883 times)
Offline gorf23
  •  190 190
« on: December 31, 2022, 09:23:14 AM »
I was working on a macro for a wxlua dialog i ran the macro and the dialog box and buttons appaired on screen and seemed to work ok.
But wouldn't close on exit, now every time i boot mach4 the dialog box loads and displays on screen but my screen is a blank page no mach4 screen set displayed..
and i still can't close the dialog box and when i exit mach4 it crashes..
any suggestion's other than starting over, i can't get back into screen edit to copy any of my newer scripts, i would like not to have to rewrite them..
Thanks gary
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Help Strange Macro Problem seems to load at startup
« Reply #1 on: December 31, 2022, 10:55:13 AM »
Run "Mach4GUI.exe  /e" from the command line, this should load you direct into the editor after selecting your profile.
DazTheGas
Offline gorf23
  •  190 190
« Reply #2 on: January 02, 2023, 04:59:19 PM »
Thanks DazTheGas
Got it working for now, till i break it again :)
Offline Bill_O
  •  615 615
« Reply #3 on: January 02, 2023, 05:01:48 PM »
When I am doing things with the Mach I make a copy of the folder before I change anything.
Then when I mess up I just delete the Mach4 folder and rename the copy.
Offline gorf23
  •  190 190
« Reply #4 on: January 04, 2023, 06:16:24 PM »
I guess I ran into another glitch..
I have the dialog working fine as it seems it's in a m code file m1005
if I place the m1005 in side a g code file it seems to run fine dialog displays good and i can run the g code file over and over and no error's
but now when I close mach4 and exit mach4, it seems to crash wants to generate a crash error file every time i close after running the dialog though g code..
It doesn't crash if I have run it with the MDI
is it not allowed to run a Lua wx dialog being called from a g code file?
