Hello
Guest
it is
October 22, 2026, 09:04:48 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
how Fire up the timer on screen set
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: how Fire up the timer on screen set (Read 5712 times)
KatzYaakov
600
on:
December 13, 2022, 06:33:39 PM »
i use the the timer on screen set to start the grease pump
its real good because can give greaze in pulses according my nedde
but i cant any way how start this timer or how stop it from script or even M function
thanks
Logged
SwiftyJ
233
Re: how Fire up the timer on screen set
Reply #1 on:
December 14, 2022, 03:28:30 PM »
Hi, you can use:
scr.SetProperty(“tmr(1)”, “Command”, “START”)
Be sure to use the name of the timer in your screen. I’m guessing STOP works as well to stop it
Logged
Print
Pages:
1
Go Up
« previous
next »
