Hello
Guest
it is
November 13, 2026, 03:15:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 Homeswitches, ARF 6040 cnc
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 Homeswitches, ARF 6040 cnc (Read 24336 times)
Fredrik
7
on:
December 11, 2022, 10:09:25 AM »
Hi
When i do Ref all home my machine dont back of my homeswitches, Yellow lights turns on in diagnostiks, M1,M2,M3.?
When i jogg machine of home the switches lights go of,
Howe do i fixt so the machin back off the switch When its triggerd ?
Fredrik
Logged
reuelt
520
Re: Mach3 Homeswitches, ARF 6040 cnc
Reply #1 on:
December 11, 2022, 11:07:35 AM »
Your machine is travelling too fast when you "ref all home".
I think the softlimits are set incorrectly. Softlimit settings must be set to slow down the speed to 40% when spindle approaches the home switches or soft limits.
Check with your user manual.
Logged
"the gift of God is eternal life through Jesus Christ our Lord"
Fredrik
7
Reply #2 on:
December 11, 2022, 11:42:25 AM »
All my Numbers are typed in from the manual,softlimits, speed in manual are set at 40%, i tryed at 20% but it doesent helpt.
Logged
reuelt
520
Reply #3 on:
December 11, 2022, 11:52:19 AM »
Are you using metric units?
The slow zone of 1 is correct if you are using inches but should be 25 if using mm
(Remember: pirated copies of Mach3 from China will not work correctly)
Logged
Fredrik
7
Reply #4 on:
December 11, 2022, 12:09:40 PM »
Yes in in metric, and in my manual the slowzone number is 1, i Will change to 25 and test.
Logged
Print
Pages:
1
Go Up
« previous
next »
