Hello Guest it is October 22, 2026, 08:53:46 PM
Author Topic: Mach4 and Windows 11 M62 P# issue  (Read 7313 times)
« on: December 10, 2022, 08:28:57 AM »
  I found that in Mach4 g-code with M62 P# will lock up intermittently.
  anyone else seen this?? I would recommend not using Windows 11 Pro.
Re: Mach4 and Windows 11 M62 P# issue
« Reply #1 on: December 12, 2022, 06:35:53 AM »
  Arc-Ok came on and stayed on until arc went out due to peirce hole to large.
  I loaded the old Mach3 Files and machine does not stop until finish with G-code so I don't belive its a noise issue.
« Reply #2 on: December 13, 2022, 06:35:22 PM »
i recommend not touch win 11 many of the drivers and inverters supplier software not work with win 11
best wait until all will update
