Hello Guest it is November 13, 2026, 11:51:45 AM
Author Topic: MACH4 newb help  (Read 26466 times)
MACH4 newb help
« on: December 06, 2022, 05:17:09 PM »
Hi all.
I have been using Mach3 for about 2 years on an avid pro4896 with no issues.
I purchased Mach4 to eventually transition and also because I understand laser functionality is better.
However, my issue is this.  I installed Mach4 on my computer (meets minimum specs) and instantly discovered that when jogging, all axis's jump, skip, stall.  It doesnt seem to matter what i set the velocity and acceleration to, it always happens.
It is particularly bad when the x and y are jogged simultaneously.
I will add, both Mach 3 and 4 are on the same computer.  I can still use mach3 without issue.  No ethernet or internet conflicts either.
Any help/guidance would be really appreciated.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: MACH4 newb help
« Reply #1 on: December 09, 2022, 02:44:03 PM »
We need a bit more detail about the motion controller you are using with Mach3 and 4
Offline reuelt
  •  520 520
Re: MACH4 newb help
« Reply #2 on: December 12, 2022, 09:05:24 PM »
Hi all.
ARE you using Avid's custom version of Mach4?
https://www.avidcnc.com/support/instructions/software/downloads/mach4/
"the gift of God is eternal life through Jesus Christ our Lord"
