Hello Guest it is November 13, 2026, 01:52:28 PM
Author Topic: How to trigger either a message, or a pop-up when input 2 is activated?  (Read 23979 times)
I have several brains working, so I can add another for this purpose, I'm just not sure how to trigger either a message or a pop-up (anything to get the users attention)
If I can't do it with a brain, is there some other way?
I tried adding the following to macropump.m1s, but it does not work (macropump is enabled in cfg), so not sure what's up with that approach?
If IsActive(INPUT2) Then
message"abc"
EndIf
I can see input 2 changing in the diagnostic page, so the hardware is okay.
If I open macropump.m1s in the VB editor and then hit the play button, it gives syntax errors for just about any valid code that I put in the script
« Last Edit: December 05, 2022, 08:19:05 PM by slow-poke »
Offline TPS
  •  2,627 2,627
Re: How to trigger either a message, or a pop-up when input 2 is activated?
« Reply #1 on: December 06, 2022, 05:49:02 AM »
try this
Code: [Select]
message "abc"
End If
