Hello
Guest
it is
November 13, 2026, 02:10:20 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach3 M10P1
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 M10P1 (Read 23623 times)
Sailsoon
2
Mach3 M10P1
on:
November 28, 2022, 02:33:07 PM »
I am new to this forum, hope this is not a repeated many times question...
How to set laser power with M10 codes as one can with M3 S* ?
Tweakie.CNC
9,377
Super Kitty
Re: Mach3 M10P1
Reply #1 on:
November 30, 2022, 04:11:21 AM »
The M11P*/M10P* commands are only for turning the laser ON/OFF to set the laser power you need to do some additional work. The easiest method I have found for adjusting laser power is detailed in this & the other linked threads...
https://www.machsupport.com/forum/index.php?topic=12444.msg265104#msg265104
Hope this helps.
Sailsoon
2
Re: Mach3 M10P1
Reply #2 on:
December 01, 2022, 01:10:21 PM »
Thank you.
Print
Pages:
1
Go Up
« previous
next »
