Hello Guest it is October 22, 2026, 02:42:17 PM
Author Topic: Motion Problem  (Read 6861 times)
Offline DanP
  •  10 10
Motion Problem
« on: November 26, 2022, 02:42:07 PM »
Building a New Router running Mach4 ESS and C25XP testing motion it jogs every direction perfect,Homes Perfect will run gcode as long as i am using G0 if i use G1 G2 G31 G83 nothing on motion no error. Not sure where to look Mach4?? ESS?? C25XP??. I am testing with Gcode that my mill runs fine Mach4 ESS MB3. Any advice is welcome. Started with 4818  ESS 275 i think, tried up grading to 5000 Ess 284 No Change.
Offline DanP
  •  10 10
Re: Motion Problem
« Reply #1 on: November 26, 2022, 05:19:23 PM »
Never mind got it!
Re: Motion Problem
« Reply #2 on: November 27, 2022, 01:48:35 AM »
where was error?
Offline DanP
  •  10 10
Re: Motion Problem
« Reply #3 on: November 27, 2022, 12:55:04 PM »
Changed feed mode from Per Rev to Per min. Now everything works as expected.
Re: Motion Problem
« Reply #4 on: July 27, 2023, 10:46:09 PM »
Great! I read your post and I also exchange Per Rev. The best result I want.
