Hello Guest it is October 23, 2026, 05:49:31 PM
Author Topic: Bitsensor LAN controller plug-in  (Read 30869 times)
« on: October 29, 2022, 03:31:14 AM »
Hi all.
I ordered Bitsensor BSMCI14E LAN controll board , but don't have plug-in , in package was board and cable only.
USB version not working good (reseting communication) , then ordered LAN version .
Seller still not send plugin , then I try here if have some one this controll board .. and can send me plug-in .
Best regards.
Re: Bitsensor LAN controller plug-in
« Reply #1 on: October 29, 2022, 03:42:35 AM »
I find it on Internet ..working..
« Reply #2 on: December 23, 2023, 05:21:17 PM »
Hi there, do you have a source for a plugin dll or the ETH PRO that the docs refer to.  I can ping the unit but without a plugin etc, Mach3 cant communicate.
« Reply #3 on: December 28, 2023, 12:51:07 PM »
You might try the USB motion driver found for a similar board listed here
https://buildyourcnc.com/item/electronicsAndMotors-electronic-component-breakout-Mach3-USB-Board
The dll properties list its filename as 'RnRMotionMini' with a trademark for 'BITSENSOR.COM'
even better maybe, the internet archive
https://web.archive.org/web/20181213082853/http://bitsensor.com/downloads/mach3insten.zip
« Last Edit: December 28, 2023, 12:58:27 PM by MarshaJ847 »
« Reply #4 on: December 28, 2023, 01:26:46 PM »
Thanks for your help.  I did find that file and tried but with no luck
« Reply #5 on: December 28, 2023, 02:16:02 PM »
Also at https://web.archive.org/web/20181213082306/http://bitsensor.com/downloads/paraminjector.zip
Is a file to change the default ethernet address... part of its readme
"The default IP address of the Board is "192.168.8.8", In order to communicate with the Board, you need setup your PC's IP address within the same subnetwork"
« Reply #6 on: December 28, 2023, 02:31:46 PM »
Thanks for the help.  The seller sent a zip file with some support docs, including the instructions on connecting to it via the network.  Have followed that and got to a point wher I can ping the board and it responds, but without the dll plugin or similar, Mach3 cant communicate with the board.  One of the docs refers to clicking on 'Eth Pro' (which is maybe like a support plugin) but I cannot find any trace of it.
« Reply #7 on: December 28, 2023, 02:44:23 PM »
Hi All. Sorted thanks ( i think).  I have bought and paid for Mach3 and are building another machine. The install file was corrupted that the seller had sent so I just used my own.  Followed the suggestion earlier and found the install file on the wayback machine and it includes all the drivers.
« Reply #8 on: December 29, 2023, 09:45:22 PM »
Hi All.  I have it communicating, thanks to the idea of the wayback machine and the now non exisitent bitsensor website.  The inputs are doing as they should however the outputs are misbehaving. When you jog any of the axis, the x, y and z all track simultaneously (on the display). The hotkeys are not mapped the same, the external mpg inputs are disabled. This is a real pain.  It only seems to be a problem when the plugin is installed, but I cant do without it because without, mach3 cant communicate with the ethernet controller.  Hmm these bitsensor boards are a pain.
Offline geast
  •  51 51
« Reply #9 on: December 31, 2025, 08:25:19 AM »
Hello all.
I try to communicate with this board but with no luck. I change the IP address of the PC ethernet card to 192.168.8.100 and althougth i get a response from card by ping at 192.168.8.8 the mach3 plugin does not "see" the card.
I try both plugins BS5Axes.dll and BsEth5.dll but none of them get a response from card.
I also try with the Paraminjector.exe to change the ip address of the card but with no luck. Only the -find works and finds the card at 192.168.8.8.
Attached are the two dll files if anyone can check them.
