Hello Guest it is October 22, 2026, 09:16:37 PM
Author Topic: Probing & Soft limits  (Read 6887 times)
« on: October 28, 2022, 02:31:05 PM »
I'm using a ESS and have my software limits setup. The machine probes correctly with the softlimits off, but if I turn them on then it will not probe. Does this with gcode from sheetcam or if I just run G31 Z -4.
Re: Probing & Soft limits
« Reply #1 on: October 28, 2022, 02:48:08 PM »
Ok, in the gcode from Sheetcam it has G31.0 Z-10. My softlimits for Z is set to 5, so I lowered this in the post to Z-4. But, this has not fixed the problem.
« Reply #2 on: October 28, 2022, 04:23:38 PM »
Limits are all very well but far less important than Home switches, and SoftLimits ONLY make sense once a machine has been Homed or Referenced.
Many people use limit switches as dual purpose, ie limit event indicators but when Homing home event indicators. I personally do not like that practice.
I have six limit switches, 2 per axis, each on its own ESS input, and three separate home switches, again each on its own input on my new mill.
My first mini-mill had three home switches only, no limits. Because it had good home switches SoftLimits worked well and  I never got around to having limits switches
and I used it like that for seven years.
How do you Home or Reference your machine?
« Reply #3 on: October 28, 2022, 04:54:27 PM »
You are confusing the Z-10 in the g31 block with SoftLimit Z. The Z ordinate in the g31 block is a work coordinate, ie referenced to the current g54 Work Coordinates
whereas the SoftLimit Z ordinate is in Machine Coordinates, ie referenced to the Machine Zero not the Work Zero.
« Reply #4 on: October 29, 2022, 05:43:06 AM »
I have home switches on all axes. I ref all axes then enable softlimits to prevent hitting hard limits. This works well with a plasma table jogging at 1500ipm.
What your saying makes sense. Lowering the Z travel in the G31 block allowed softlimits to work. Now, I need to figure out adjusting settings in the post for the ref distance.
