Hello Guest it is November 01, 2026, 08:09:45 AM
Author Topic: Torch wont stay fired  (Read 33133 times)
« on: October 27, 2022, 06:00:22 PM »
I'm running ESS/TMC3in1 and when I try to cut. It probes and raises up fires the torch then the torch goes out. The message I get is: !!!!ESS: Arc Okay (THC ON) Went Out!!! Activating feedhold.
I double check the CPC port and J7 ports and all that is wired correctly. Any suggestions?
