Hello Guest it is November 22, 2026, 08:07:16 AM
Author Topic: Z start height  (Read 23177 times)
Z start height
« on: October 23, 2022, 05:03:50 AM »
Morning all finaly got a work around to get my machine up and running,
On doing so i need to alter some code in one of the files.
Symtoms
When i start a Gcode of to machine the Z axis comes down to +60mm above the work plane. then the spindle fires up and work commences.
my issue is I have a job thats 100mm thick and i only have 22mm above the material and cutter.
any easy way to change that 60mm to 20mm??
regards Tom
Re: Z start height
« Reply #1 on: October 24, 2022, 05:24:30 AM »
Managed to find the issue and resolve,
On my M6 Start macro the Z was set to Z60. so changed to Z20 can cut 100mm again,
Re: Z start height
« Reply #2 on: October 24, 2022, 05:53:40 AM »
I'd suggest you delete that line of the macro, it will o ly cause trouble later.
