Hello Guest it is October 20, 2026, 11:40:33 PM
Author Topic: Weird arcs and circles in my Mach3 toolpaths  (Read 29347 times)
« on: October 21, 2022, 11:13:36 PM »
I am trying to generate simple turning toolpaths for Mach3 with Fusion 360... I keep getting stray arcs and circles as in the (hopefully) uploaded example image. I went through this several years ago and someone told me how to fix it and now I forget. I usually just use the turn wizards for most of the hobby stuff I do. PLEASE HELP... I'm loosing it... <It will be a short trip>
Re: Weird arcs and circles in my Mach3 toolpaths
« Reply #1 on: October 22, 2022, 06:34:40 PM »
Mach3 uses natively 'incremental arcs'. Fusion is producing arcs using 'absolute'.
In the Fusion Mach3 post select Incremental Arcs and you'll be fine.
« Reply #2 on: October 23, 2022, 06:31:33 PM »
Thank you so much for the reply... I just cannot figure out where I make this change. Do I have to edit the post file itself?
I will upload the choices that Fusion lists and have marked the only thing that seems the make the problem seem to go away, but I and sure I am doing the wrong thing.
I looked at the post file itself and that is way over my head.
Thank you so much in advance for any help of clue you or anyone can offer.
-Joemac
« Last Edit: October 23, 2022, 06:34:14 PM by Joemac »
« Reply #3 on: October 24, 2022, 03:00:40 AM »
its called Radius Arcs.
« Reply #4 on: October 24, 2022, 08:59:46 PM »
Thanks Craig, set to radius arcs and still get unexpected results. And I am in the dark about what circular radius is all about. 3 different setting get me 3 different results. I will post some images to help clarify.
It is a number but is it degrees, inches or just an imaginary number. <Grin> :-\
