Hello Guest it is October 22, 2026, 01:55:38 PM
Author Topic: edit screen  (Read 62724 times)
edit screen
« on: October 17, 2022, 02:16:15 AM »
good morning
I added pages to this screen everything works except the arrow keys, I try to explain myself better in the normal pages the direction keys (right arrow, left arrow etc. etc.) work well, in the pages I added they do not work, there is someone (more experienced than me) who can help me solve the problem? where am i wrong?
I use MachScreen 1.73
I thank anyone who can help me
Re: edit screen
« Reply #1 on: October 17, 2022, 03:51:59 AM »
Hi birillo 1959
I'm not sure I understand what you saying. Could you please show your screenset files, or email them to me (klaus.dietz@kd-dietz.de)
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: edit screen
« Reply #2 on: October 17, 2022, 04:47:18 AM »
ok klaus danke für die antwort, ich versuche mich besser zu erklären,
Ich versuche, das Itascreenset_V2-Screenset zu ändern, zu dem ich eine Seite (17) hinzugefügt habe. Auf allen anderen Seiten kann ich die Achse mit den Pfeilen (Tastatur) bewegen, während sie sich auf der hinzugefügten Seite nicht bewegen. Ich kann nicht verstehen, wo ich falsch liege !!
ps mit google übersetzt
Re: edit screen
« Reply #3 on: October 17, 2022, 05:15:13 AM »
Hi
please try to set a "reset" button on page 17. That should solve your problem. If this doesn't help, please let me know.
Klaus
Re: edit screen
« Reply #4 on: October 17, 2022, 05:25:22 AM »
ok versucht, die Reset-Taste auf Seite 17 einzustellen
das problem bleibt
Re: edit screen
« Reply #5 on: October 17, 2022, 05:29:08 AM »
Hi
could you please send me you screenset including the bitmaps. You could use MachScreen File-> Project export.
Klaus
Re: edit screen
« Reply #6 on: October 17, 2022, 05:43:55 AM »
per E-Mail gesendet
Re: edit screen
« Reply #7 on: October 17, 2022, 06:00:45 AM »
Hi
I tested the buttons, they worked like your buttons on page "Modo automatico". All axis were set to "0" with the "Azzera". Could you please explain the behavour in more detail.
Did you reload the screenset in Mach3 after changes in MachScreen?
Klaus
« Last Edit: October 17, 2022, 06:05:55 AM by Klaus1311 »
Re: edit screen
« Reply #8 on: October 17, 2022, 09:10:22 AM »
ok ja, ich habe auch den Neustart versucht, aber nichts, ich habe Ihnen ein Video des Problems per E-Mail geschickt
Re: edit screen
« Reply #9 on: October 17, 2022, 11:04:14 AM »
you need to set "jogmode" on page 17. You did this on page 1 using button "Jogmode toggle".
Klaus
