Hello Guest it is November 19, 2026, 12:51:54 AM
Author Topic: Mach3/GCode starting point question...basic question  (Read 15684 times)
« on: September 29, 2022, 09:33:44 AM »
I am just starting down the road of using Mach3 and Shape3D (creates the GCode file) for shaping surfboards.
I haven't been able to find a definitive answer regarding the tool starting point options.
The Shape3D software uses the tool home position as a starting point you can choose other points but would prefer to just start at the work piece given various sizes of the work pieces.
Is there a way to do this using Mach3 or do I have to always configure the start point in Shape3D (GCode)
Offline reuelt
  •  520 520
Re: Mach3/GCode starting point question...basic question
« Reply #1 on: November 23, 2022, 12:41:33 AM »
Work coordinates are different from Machine Coordinates and are defined under G54 (default) to G59.
Under G54, you move the cutter point to where you want the starting point to be and then set x , y and Z to zero.
Then only you start the G-code program.
You can always save the coordinates under G55-G59 so that you can recall different origins.
"the gift of God is eternal life through Jesus Christ our Lord"
