Hello Guest it is October 24, 2026, 06:47:32 PM
Author Topic: Serial-rtu Modbus baudrate up to 1000000kbps!  (Read 13725 times)
« on: September 28, 2022, 08:32:46 AM »
Please add the ability to manually select modbus (serial-rtu rs485) baudrate . I am not satisfied with the maximum baudrate of 115200kbps and now I have to manually change the speed in Machine.ini.
USB FTDI rs485 Converter allows to increase the baudrate up to 1000000kbps
« Last Edit: September 28, 2022, 08:41:57 AM by duritskiy »
Re: Serial-rtu Modbus baudrate up to 1000000kbps!
« Reply #1 on: September 28, 2022, 04:01:44 PM »
does the MODBUS device to which you are connecting go that fast? The fastest setting I've ever seen on a MODBUS device is 115.2kbps no matter how fast the serial
link is.
« Reply #2 on: September 29, 2022, 02:17:05 AM »
my device is not standard - it can
« Reply #3 on: September 29, 2022, 02:39:12 AM »
As you can see, with a baudrate of 1000000 and also using a USB-RS485 converter (FTDI chip) I was able to read two read functions in 26ms - which equates to about 40Hz.
I am very pleased with the result.
« Reply #4 on: September 29, 2022, 02:49:34 AM »
Although at baud rate 115200 - the same read functions are read in 33ms.
Which is also very good.
All this thanks to the ftdi chip - it has the lowest latency among all USB-rs485 converters
« Reply #5 on: September 29, 2022, 02:18:19 PM »
MODBUS is quite a versatile communication protocol and has a huge established base......but it was never a blindingly fast protocol.
If you want really fast low latency comms then Ethernet or better, EtherCat, is the answer.
« Last Edit: September 29, 2022, 02:32:46 PM by joeaverage »
« Reply #6 on: September 30, 2022, 12:54:26 AM »
why you think about speed with rs485?
rs485 its not close to be real time ,its can monitor the device or command the device but always with delay its not way to  interpolate  several axiss
or some thing like that,so speed ....9600 its more then need
Offline smurph
  •  1,575 1,575
« Reply #7 on: September 30, 2022, 09:36:14 PM »
The serial speeds are actually coming from the MODBUS library we use.  I'll ask them to see if they will make it customizable.
Steve
« Reply #8 on: October 01, 2022, 02:58:02 AM »
I work with what I have. And I have a breakout board for ESS SSM Ethernet, which includes STM32 as a port extension. And the connection between them is just rs485.
« Reply #9 on: October 01, 2022, 03:02:48 AM »
There is a possibility to use non-standard baudrate.
I already use these settings now and it works.
[Machine.ini]
Baud=1000000
