Hello Guest it is October 24, 2026, 06:47:20 PM
Author Topic: Question on upgrade  (Read 6620 times)
Question on upgrade
« on: September 17, 2022, 02:23:05 PM »
I purchased Mach4 with my AvidCNC machine about a year and a half ago.  I've noticed that there is now a version 2 of Mach 4.  Should I upgrade to that version?  If I do, does my existing license cover the cost or do I have to purchase a new license?  I have been having some issues with 3-D models, so I'm just thinking that it might be worthwhile to upgrade.
Your thoughts would be appreciated.
Mike
Re: Question on upgrade
« Reply #1 on: September 17, 2022, 02:54:59 PM »
Version 2 has been out for several years and you almost certainly are running it already.
If you go to >Help >About you will get a screen that shows Version 4.2.0. x x x x where
the 4 means means the product is Mach4, the 2 means version 2 in the Mach4 series,
0 is the sub-version, and x x x x is the build number of the software that you are running.
If you are not having any problems, there is no need to update your software.
There are production releases that are available on the Download page for Mach4, and
also beta versions on a separate FTP server.
There are normally no update charges for Mach software within a product series,
i.e. product 4 for Mach4.
« Last Edit: September 17, 2022, 02:57:06 PM by Steve Stallings »
Steve Stallings
www.PMDX.com
« Reply #2 on: September 17, 2022, 03:14:21 PM »
Thank you, sir!
« Reply #3 on: September 17, 2022, 06:03:58 PM »
Thanks, I do have 4.2.  Just trying to keep up to date as I am having trouble with some of the 3-D models. (see post below)
Mike
