Hello Guest it is November 19, 2026, 12:29:42 AM
Author Topic: G55 problem  (Read 15263 times)
G55 problem
« on: September 10, 2022, 04:42:24 AM »
so we have a machine with mach3 with dual head 2 spindels (we made the machine and put the setting for  the mach3 )
tool 1 is g54 offset and tool 2  is g55 offset good .
first i define  the offset for each tool
2 .start the job with tool1
3. a tool change command  in the gcode file is send
4.machine move to the second  tool offset and start working normal
5.now if i press pause button and then press start .problem happen now
so the assume it self in g54 and move to the current line position but in g54 offset. (part origin = x=0,y=0 and lets g54 is offset  x=0,y=0 and g55 offset is x=15,y=0 , and current line is go to position x=100 so it will move to position x=100 not 115 )
so can any one help
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G55 problem
« Reply #1 on: September 15, 2022, 05:36:33 PM »
I would look at using G52 and forget about using G55.
G52 is active until cancelled with G52 X0 Y0
Example
#100 = 15. (X offset T2)
#101 = 0    (Y offset T2)
T1 M6
G52 X0 Y0
G00 X0 Y0
(rest of tool 1)
T2 M6
G52 X#100 Y#101
G00 X0 Y0
etc...
(end of tool 2)
G52 X0 Y0
M30
