Hello Guest it is October 24, 2026, 11:46:16 PM
Author Topic: A question about lathe machines.  (Read 5261 times)
« on: September 05, 2022, 07:57:02 AM »
I suddenly made a lathe machine one day.
Make it easy, connect the electrical wiring, and ask questions while preparing for operation
I'm confused about not being able to initialize the x-axis to zero.
If I was going to process a 20mm round bar and installed a 30mm material, would I need an input of 30mm somewhere?
I entered the tool offset for the tool.
If so, is the offset automatically determined according to the tool when the tool is used?
For example, if the tool is 10mm from the center,
When I command G00 X30, in the case of tool 0, it automatically moves to 20mm and
will proceed with the work?
Sorry. I'm new to lathe machine, so I want to understand the concept.
