Hello Guest it is October 20, 2026, 02:51:31 PM
Author Topic: Grounding Stepper Motor Driver  (Read 29094 times)
Offline kolias
  •  1,165 1,165
« on: September 05, 2022, 05:14:26 AM »
On a stepper motor driver we have the high voltage section where we connect the required power and we also have the signal section where the wiring from the stepper motors connect.
I use shielded cables for both the high voltage and signal sections and my question is do I ground the shielded cable in both sections or just the high voltage or signal section?
Nicolas
Re: Grounding Stepper Motor Driver
« Reply #1 on: September 06, 2022, 04:41:58 AM »
 I would ground the signal wiring, but only one end of the shield not both. the high voltage side does not need to be shielded in my opinion.
Regards
Charlie M.
« Reply #2 on: September 06, 2022, 04:47:10 AM »
 I meant ground one end of the signal shielding.
Regards
Charlie M.
Offline kolias
  •  1,165 1,165
« Reply #3 on: September 06, 2022, 07:58:57 AM »
Thank you Charlie, I will ground one end of the signal shielding
Nicolas
Offline kolias
  •  1,165 1,165
« Reply #4 on: September 12, 2022, 11:03:22 AM »
To my experience grounding the signal side of a driver (A in the attached picture) is wrong, that’s the cable connected to the BOB. It almost twisted my gantry because the Y axis motor turned much faster than the slaved A axis.
Then I grounded the high voltage (D), that’s the cable handling the feed to each stepper motor and then all was good.
Nicolas
« Reply #5 on: September 12, 2022, 11:59:51 AM »
We're talking about grounding the shielded cable shielding. Not any signals.
Regards
Charlie M.
Offline kolias
  •  1,165 1,165
« Reply #6 on: September 12, 2022, 12:35:16 PM »
Yes, grounding the shielded cable shielding
Nicolas
