Hello Guest it is November 25, 2026, 05:12:21 AM
Author Topic: Is This a Helix Cut?  (Read 23347 times)
Offline kolias
  •  1,165 1,165
« on: August 27, 2022, 01:09:37 PM »
Did another cut today but I noticed something which although not visible if you don’t know about it I noticed only because it reminded me of a helix cut I did years ago on a piece of 1/2" thick aluminum.
The bit enters the stock in a helix axis rotation to avoid excess load to the bit and today in my cut, as well as yesterday I noticed when the bit touches the material is swings just like a half helix cut. In the attached pictures you can see the complete cut + an enlarged picture where I point with 3 arrows the start of each cut.
When I did the drawing in my CAM I looked at the bit parameters but I noticed nothing about a helix cut or similar. It only happens at the start point and the rest is fine. I don’t think its because of loose axis or spindle cause if it was that it would have happened when the bit changes direction to complete a geometrical shape.
Any idea why it happens and perhaps where to look for to fix it?
Nicolas
Re: Is This a Helix Cut?
« Reply #1 on: August 28, 2022, 02:31:54 PM »
 Can you post your G code?
Regards
Charlie M.
Offline kolias
  •  1,165 1,165
« Reply #2 on: August 28, 2022, 02:42:03 PM »
That is the cut I did yesterday and post the above pictures. It is a .NC file
Thank you
Nicolas
