Hello Guest it is October 22, 2026, 01:46:51 PM
Author Topic: Lathe calibration problems  (Read 26020 times)
« on: August 21, 2022, 11:04:44 AM »
Hi. After help from a member of this forum I was able to get the number of steps correct to calibrate the axis. However I have hit a second problem. If I enter let’s say x-40 in the g-code box. The motor turns but very very slowly. No matter how I set it in motor tuning it just moves slowly. If I jog the axis it moves at speed. I just don’t know what’s going on. How can I tune the motor if means nothing in the program. What am I doing wrong. Thanks.
Re: Lathe calibration problems
« Reply #1 on: August 21, 2022, 11:10:09 AM »
What g code command do you use?
« Reply #2 on: August 21, 2022, 01:21:10 PM »
Hi, I just input z-20. Mach3 is set for mm.
« Reply #3 on: August 21, 2022, 04:21:47 PM »
This is in the MDI right?  Try G01  Z-20 F50
« Reply #4 on: August 22, 2022, 02:41:22 AM »
Ok, will do
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #5 on: August 22, 2022, 08:38:50 AM »
If you enter G01 G91 Z-10. F50. the machine will move in incremental steps of 10mm.
