Hello Guest it is October 25, 2026, 12:01:07 AM
Author Topic: Torch Cutting Problem  (Read 22404 times)
« on: August 06, 2022, 09:35:49 AM »
Im Stuck,
I just built my first plasma table. So I am new to mach3 and cnc. The problem I am having is when I run the gcode with no metal for the torch to cut..it fires and works perfectly threw the gcode.   When I attempt to cut metal with it all it will do is pierce the metal at every entry point and not keep the torch going. The plasma cutter is a pilot start. I have grounded the plasma table to its own grounding rod. I have to constantly keep hitting the torch on off button on mach3 to keep it firing when it is cutting metal. On mach 3 it shows that the torch is turned on during the run. I im pretty sure it is since once i remove the metal it fires fine. I do not have a thc I am just setting the cutting height manually.
My break out board is SainSmart 5 Axis Breakout Board for Stepper Motor Driver CNC Mill
I have the 2 pin connector on the plasma cutter wired up to the relay on the break out board.
My Plasma Cutter is a
TOOLIOM 50A Non High Frequency Plasma Cutter Non-Touch Pilot ARC 110/220V Dual Voltage Cutting Machine 1/2" Clean Cut
Thank you for your time
Jeremy
Re: Torch Cutting Problem
« Reply #1 on: August 10, 2022, 03:23:52 AM »
Here are 2 videos. One with me trying to cut metal. The other just firing into the air. It works perfect when just firing into the air. Thanks
https://youtu.be/Ql9vFBj4EFw Trying to cut metal
https://youtu.be/SXnfkKTgg5g firing it into the air
