Hello Guest it is September 25, 2026, 08:17:56 AM
Author Topic: The command for the X axis goes to the Y axis  (Read 21815 times)
« on: August 04, 2022, 03:40:10 AM »
Hi There,
I'm a beginner and I'm trying to control KitMillQT100 from Original Mind in Japan with mach3. I connected the device to the PC on which mach3 was installed, and set the mach3 parameters. As a result of using jog to operate up, down, left, right and Z axis, the direction of each axis movement was normal. The device moves according to the G code created with Fusion360, but there is one problem. The command for the X axis goes to the Y axis, and the command for the Y axis goes to the X axis, so cutting is performed at an angle of 90 degrees to the G code.
Could you show me which part of the settings screen I should change?
Yokotsuna
