Hello Guest it is October 25, 2026, 12:31:53 AM
Author Topic: Start VB Script with button wired to input  (Read 34350 times)
« on: August 03, 2022, 10:11:33 PM »
Hi there.
  I have a simple VB Script to Auto Zero my spindle.  Can I run this script by pushing a button wired to an input on my machine?  I have buttons wired (start/stop etc) I want to replace one of those with running my script.
Thanks!
Offline TPS
  •  2,627 2,627
Re: Start VB Script with button wired to input
« Reply #1 on: August 05, 2022, 03:41:11 AM »
basicly OEMTriggers are used like regular input's but they Special functionalty
1st. you can assign in Config->System hotkeys oemcodes to a OEMtrigger witch will be done once if OEMTrigger comes true
2nd. you can define a triggermacro by SetTriggerMacro(number)
normaly done this way.
-add for example in Config->General Config ->Initialisation string  M333, that means every time you reset M333.M1s is called
-within M333.M1s add the VB code SetTriggerMacro(334)
-assign in Config->System hotkeys oemcodes to a OEMtrigger the code 301 witch means run triggermacro
so every time the OEMTrigger Comes True the VB Code within M334.M1S will run once.
hope i was able to explain the Basics of OEMTriggers in my bad bavarian english.
« Reply #2 on: August 05, 2022, 05:12:41 AM »
Thank you very much. That all made complete sense! Perfect. To push it one step further, what if I had more buttons wired to inputs? With the SetTriggerMacro option, using OEM code 304, this would only allow for one macro after button push. Is there a way to set up other buttons in this way?
Thanks again for your reply it was extremely helpful!!
Offline TPS
  •  2,627 2,627
« Reply #3 on: August 05, 2022, 05:16:49 AM »
the oemcode for the triggermacro is allways 301!
in my example it will allway run macro M334.M1S
within this macro you can select the oemtrigger via script:
Code: [Select]
If Oemtrigger(1) Then
     'do code for Oemtrigger1
End If
If Oemtrigger(2) Then
     'do code for Oemtrigger2
End If
'and so on
« Reply #4 on: August 05, 2022, 05:19:36 AM »
Perfect, thanks again!
