Hello Guest it is October 25, 2026, 12:21:56 AM
Author Topic: mach3 xhc WHB04B mini lathe  (Read 22552 times)
Offline frapo
  •  11 11
« on: July 30, 2022, 02:51:47 AM »
hi i have the XHC WHB04B pendant and i like it very much,but there is one thing that i cant find out.
The z axe dro output are the same on pc and pendant,but my x axe shows different numbers,e.g- x axe on pc 100 mm  and the pendant shows 50 mm or is that normal.
Re: mach3 xhc WHB04B mini lathe
« Reply #1 on: July 30, 2022, 08:10:21 AM »
Lathe set to diameter mode but the pendant either isn't set or doesn't recognise it.  Mach 3 should say diameter mode under the dros.  Just ignore the pendant.
