Hello Guest it is November 18, 2026, 11:45:54 AM
Author Topic: DIY pendant & Visual LCD Studio  (Read 7241 times)
« on: July 30, 2022, 01:26:43 AM »
Re. DIY pendant - there were a few posts from 2020 but I would appreciate if anyone could comment on their experience.
I am running Mach4 on my CNC and wish to add a pendant. I have built Simon Rafferty's design from GitHub.
My Mach4 screen set recognises the pendant, I can monitor the serial data which appears to be correct so far but the display is not updating. I suspect that my problem is with the Hunda HB35-1C display.
Has anyone had success with the Visual LCD Display software? I can compile, download (upload) the Hunda example and Simon's script to the Nano.
I can compile, load and get the example to work with the Visual LCD Studio software.
However the Lcds Test & Touch Panel Test do not appear to do anything.
I have Visual LCD Studio software ver 1.1.2.0. Is there a later version?
Thanking you in advance for any help.
Re: DIY pendant & Visual LCD Studio
« Reply #1 on: July 30, 2022, 03:50:38 AM »
what motion controller are you using?. Do you have five , or six or more spare inputs?
If you do why shag around and just make a wired pendant?
I made one to replace my VistsaCNC pendant, I wore it out over seven years and thought I'd make one.
Real simple, has two wires for axis selection, one for velocity/incremental mode, two wires for A&B of the MPG, and two wires for
power and return. Seven wires but only five inputs required. Works OK.
« Reply #2 on: August 02, 2022, 03:51:31 AM »
from his github:
Code: [Select]
The vendor will send you a link to the software & documentation. The link they sent me is below, however I dout it will persist there very long. If the vendor won't cooperate, message me & I'll send a copy if I still have it.
looks like a finalized or dead endeavor.
DIY is expensive...I've done it..complete with 3d printed case:
https://github.com/kethort/esp32-cnc-mpg-handwheel-conversion-mach4
or
https://github.com/kethort/esp32-bluetooth-cnc-mpg-mach4
only thing it lends you is freedom to determine the logic
« Last Edit: August 02, 2022, 03:54:01 AM by compewter_numerical »
