Hello Guest it is October 24, 2026, 10:57:48 PM
Author Topic: Mach 3 software  (Read 22231 times)
Mach 3 software
« on: July 26, 2022, 08:52:07 AM »
My machine progressively cuts deer as it continues through the files. starts out fine but ends up deer at the end. I made sure everything was level and I also ran a program to level the spoil board. To give you an example i would create a file in carveco cutting an 7.5" circle and offset it to the inside 1/2". The file would start cutting on the very inside circle and cut each circle outwards. each circle it cut would progressively get deeper. I also did the same with a square file with the same results. Any suggestions???
Re: Mach 3 software
« Reply #1 on: July 27, 2022, 04:09:34 AM »
 Is you bit sliding out of the collet?
Can you post your G code file?
Regards
Charlie M.
