Hello Guest it is November 10, 2026, 01:38:48 AM
Author Topic: position memorization  (Read 17614 times)
« on: July 25, 2022, 01:35:19 AM »
good morning
I found on the net this macro stores x axis in the file
since I am not capable of it, is it possible to modify it for all the axes? possibly for "X and Y". I thank those who can help me!
 This example creates a file called myFile.txt in the Mach3 folder. It then reads the current position of the X-axis and writes it to the file. Lastly it closes the file.
Dim X as Double
  Open "C:\Mach3\myFile.txt" For Output As #1
  X = GetDRO(0)
  Print #1, X
  Close #1
And here's code that opens the file created in the previous example and reads a single line from it. It then asks the user if it's OK to move the X-axis to the position stored in the file.
Dim Answer
Dim newPos As Double
  Open "C:\Mach3\myFile.txt" For Input As #2              'Open the file for reading
  Line Input #2, newPos                                                      'Read the first line of the file
  Answer = MsgBox ("Is it OK to move the X axis to: " & newPos & "?", 1)
  If Answer = 1 Then                                                           'You pressed OK
    Code "G0 X"& newPos                                                  'Make the move
  End If
  Close #2        'Close the file
Re: position memorization
« Reply #1 on: July 25, 2022, 03:30:43 AM »
This is an ideal learning opportunity for you.  Most of the clues you need are there in the macro you already have.
« Reply #2 on: July 25, 2022, 03:56:54 AM »
John Haine thanks for the answer, tried and tried again I don't come to the head, I know it could be easy to modify it but I'm not really capable !!!! programming are at 0, even less !! :( :(
Offline TPS
  •  2,627 2,627
« Reply #3 on: August 05, 2022, 03:47:55 AM »
Code: [Select]
Dim X,Y as Double
  X = GetDRO(0)
  Y = GetDRO(1)
  Print #1, X
  Print #1, Y
  Close #1
Code: [Select]
Dim Answer
Dim newPosX, newPosY As Double
  Line Input #2, newPosX                                                      'Read the first line of the file
  Line Input #2, newPosY                                                      'Read the second line of the file
    Code "G0 X"& newPosX & " Y" & newPosY                                                  'Make the move
  End If
  Close #2
NOT TESTED
« Reply #4 on: August 05, 2022, 05:43:10 AM »
Good morning
Thanks for your help.
I tested it and it works perfectly, only problem (if you can 'define what i' !!) in the file, after the point, it stores too many numbers
22.000000003381
32.999999998041
I don't know if it can be changed, but it's irrelevant.
thanks TPS for the help offered !!!!!
Offline TPS
  •  2,627 2,627
« Reply #5 on: August 05, 2022, 05:54:24 AM »
we had the same couple of day's ago:
Code: [Select]
Dim X,Y as Double
  X = GetDRO(0)
  Y = GetDRO(1)
  Print #1, nFmt(X,4)
  Print #1, nFmt(Y,4)
  Close #1
« Last Edit: August 05, 2022, 05:56:42 AM by TPS »
« Reply #6 on: August 05, 2022, 06:54:35 AM »
perfect!!!! everything works great !!
sorry if I abuse your patience but programming are at 0 (even something less :()
greetings and thanks :)
