Hello
Guest
it is
October 24, 2026, 02:04:44 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Go to z zero command
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Go to z zero command (Read 5753 times)
ROTM
24
on:
July 19, 2022, 09:14:00 AM »
Good day.
If I have a work piece and set the x,y,z to zero.
Mach4 has the button to go to x,y to zero.
how can I do this to the z as well and later on put a button to use the command.
Thank you!
Logged
Bill_O
615
Re: Go to z zero command
Reply #1 on:
July 19, 2022, 11:28:53 AM »
Both will take a little minor programming.
If you are talking about the button that says "Go To Work Zero" it has two choices for movement.
One includes the Z to zero but is commented out.
I can direct you on how to do it but you will have to do it.
Here is something I made when I was trying to learn how the programming is done.
It might help.
https://www.machsupport.com/forum/index.php?topic=45397.msg289143#msg289143
Bill
Logged
Print
Pages:
1
Go Up
« previous
next »
