Hello Guest it is October 24, 2026, 09:43:40 PM
Author Topic: fusion 360 to mach3 mini lathe.  (Read 21275 times)
Offline frapo
  •  11 11
« on: July 18, 2022, 12:57:54 PM »
as i am still learning i use the turn wizzard.
I fill the data in the turn wizzard and post it to mach3,then i go in the manual screen and set the beginning point for my workpiece with part zero. zero z.
Its worked perfectly no problems
But when i post a drawing with fusion360 to mach3 and setting my zero z in manual mode the program begins not even close to my workkpeace,infact my x axe goes al the way backwords + is that
