Hello Guest it is November 19, 2026, 12:13:49 AM
Author Topic: Alarm 27 NO AXES COMMANDED IN G43/G44  (Read 15959 times)
« on: July 15, 2022, 07:34:12 AM »
I'm using a Right Angle Head and I'm not able to figure out what's causing this error.
I've attached a G-Code file that's giving the error.  I know there is an issue in the combination of machine and control definitions and post file in mastercam, but I should be able to see the result in the G-Code.  I'm just not seeing what's causing the issue.  I have other programs that use the RAH without any issues.
Thanks for any help.
Re: Alarm 27 NO AXES COMMANDED IN G43/G44
« Reply #1 on: July 25, 2022, 01:20:46 PM »
Has anyone seen this error or used a RAH?
I'm just not sure what I'm missing.
« Reply #2 on: July 27, 2022, 12:02:47 PM »
For anyone that stumbles on this, it turns out my post file was not adding a Y value after the
N350 G18 G43 H42
I added Y0.001, and have been good since.
