Hello Guest it is October 24, 2026, 10:36:17 PM
Author Topic: Command to open a specific Wizzard ?  (Read 6447 times)
« on: July 01, 2022, 06:59:17 AM »
Hello everyone,
I am making my custom screen and i need a button to open a specific wizard. I found the command to load a specific GCode but not a wizard.
I know i can set it to open the last wizard but it dosen't suit my usage.
To explain my setup, i made a custom wizard to generate a GCode file for my machine. I then open it and run it.
Thanks for your help !
Re: Command to open a specific Wizzard ?
« Reply #1 on: July 06, 2022, 01:48:21 PM »
Can you just copy the code from the wizard into a button on the screen?
Alternatively you could try the following API. But I am not sure if it is appropriate to use this call for running wizards
Code: [Select]
rc = mc.mcScriptExecute(
number mInst,
string filename,
number async)
