Hello Guest it is November 10, 2026, 01:39:04 AM
Author Topic: Starting a VBScript from am Button?  (Read 17452 times)
« on: June 17, 2022, 07:24:08 AM »
Hi guys...
i build a lathescreen.
now i have on 3 sites the same button with the same code...
if i want to change something on the code i must copy&past it to all 3 sites...
is there a way to to make changes in a .m1s file?
my attemp was:
button starts oem code 34 (basic script)
in the line for the script i put in :
Code "Button1.m1s"
then i make a file in the correct directory with the name Button1.m1s
to test it i put in the file :
Code "F300"
i get error when i hit the button in mach3....
if i  name the file M4444
and change on the button from button1.m1s to m4444.m1s it works.
what do i wrong?! thanks
Offline TPS
  •  2,627 2,627
Re: Starting a VBScript from am Button?
« Reply #1 on: June 17, 2022, 12:04:33 PM »
have a look to this:
https://www.machsupport.com/wp-content/uploads/2013/02/Mach3_V3.x_Macro_Prog_Ref.pdf
and then look for #Expand maybe this help's
« Reply #2 on: June 17, 2022, 12:13:16 PM »
Thanks.. yes i read it but i dont understand it...
my solution is to use m4444 for the code... but i hope someone have a example what i understand :)
thanks
Offline TPS
  •  2,627 2,627
« Reply #3 on: June 18, 2022, 05:17:08 AM »
you create a macrofile in the holder  c:\Mach3\macros\Your profile name
let's say MyFuntions.m1s
in the file MyFuntions.m1s you place a function with the code:
Code: [Select]
'function for button1 ------------------------------------------------
Function Button1() as Boolean
        Code ("F300")
End Function
now in any button you can use this code:
Code: [Select]
Sub Main()
Call Button1()
End Sub
#Expand <\..\..\macros\Your profile name\MyFunctions>
so you can keep the specific code in just one file -> MyFunctions.m1s
and you can add as may functions you want.
« Reply #4 on: June 18, 2022, 05:44:30 AM »
ok thanks! i will try it!
« Reply #5 on: June 20, 2022, 12:03:09 PM »
works perfect! Thanks!!!!
