Hello Guest it is October 25, 2026, 12:36:39 AM
Author Topic: Unexpected tool path  (Read 6126 times)
« on: June 13, 2022, 11:52:19 AM »
Hi
Ok, I'm experiencing some strange tool path results.
using Autodesk Invento, I drew a test wing profile section and generated the tool path using the Autodesk CAM plugin. The toolpath can be viewed in the editor and looks like I would expect.
https://drive.google.com/file/d/1Ihvrrio3QbMIX6UTSGOqkDgJKWmvFDEn/view?usp=sharing
However, when I copy the file to my CNC machine and open the file in Mach4 the toolpath looks somewhat different.
https://drive.google.com/file/d/1gjnzucI-WIYFCH7ps0HbM3Bs0fTcTGas/view?usp=sharing
I have no idea where these circles come from and what they are for. I need to delete these but don't really want to scroll through 20add thousand lines to find and delete the.
Any ideas???
Re: Unexpected tool path
« Reply #1 on: June 13, 2022, 03:15:57 PM »
try using Radius Arc option in the post processor.
« Reply #2 on: June 14, 2022, 01:17:45 AM »
I resolved the issue, was my own doing
I did not select Mach as the destination system that will use the code. Once I defined that in the post-processor it all looked a lot better.
Kobus
