Hello Guest it is August 29, 2026, 02:07:06 PM
Author Topic: Best 2-state button  (Read 16857 times)
Offline drew
  •  79 79
Best 2-state button
« on: October 26, 2007, 07:57:32 PM »
OK let me know which 2-state button IYO is best. Thanks Drew
« Last Edit: October 26, 2007, 08:00:21 PM by drew »
If I had something important to say it would be here.
Re: Best 2-state button
« Reply #1 on: October 26, 2007, 09:44:42 PM »
Hey Drew,
   They all look really good.  :) I like the top one best.
« Reply #2 on: October 27, 2007, 03:44:20 PM »
I too like the top best
Offline Tarak
  •  229 229
« Reply #3 on: October 30, 2007, 05:51:33 PM »
I concur the top button is best, I've also been making buttons using the same pic but a different colour for different states.
I'm having trouble after I set an PNG LED then set an image button with no picture, so in theory it's a transparent button, but after overlaying it with the LED the LED doesn't show up correctly.
I tried to diagnose the problem by moving the transparent button half way off the LED. You can see what happens.
BTW I'm using Screen 4.
Offline drew
  •  79 79
« Reply #4 on: October 30, 2007, 07:25:18 PM »
The led doesn't work right if there is no image attached to the button. (see previous post topic about 2 state buttons) You can use a transparent.png and it works fine. Heres the one that I ues.  BTW your home light looks great. I also use screen4.
Drew
Offline Tarak
  •  229 229
« Reply #5 on: October 30, 2007, 08:02:17 PM »
Thanks Drew, it works great, I've attached the home LED so you can use it if you like.
Page in Screen 4
« Reply #6 on: November 25, 2007, 07:00:19 AM »
 I need your help because I can’t move forward with Screen 4. Please, watch in the video Screen 4 .wmf that the pages change correctly as well as the images of the buttons.
            When I do the same thing in Mach 3, the pages change correctly but the images don’t. Notice in the video mach3.wmf that sometimes the images change correctly, sometimes incorrectly and sometimes they appear with a white stripe. I’ve spent days trying to make other configurations but I cant’ remove the error and keep on developing the interface.
thanks
Offline drew
  •  79 79
« Reply #7 on: November 25, 2007, 09:42:28 PM »
Scroll down to  Reply #4 and read this topic http://www.machsupport.com/forum/index.php/topic,3389.0.html
If that info doesn't fix your problem ask zealous aka 'The Screen Master'
Drew
