Hello Guest it is October 25, 2026, 12:36:35 AM
Author Topic: Fusion 360 In-Process Inspection  (Read 15097 times)
Re: Fusion 360 In-Process Inspection
« Reply #10 on: June 13, 2022, 02:04:26 PM »
Yes.  I've got OD Grinders that I made the code for that utilize all of those; I'm using Mach4 industrial on those machines.
OK, so it's really upgrade (which my OEM is stepping all over me anyways, time to break that cycle of frustration) and start implementing these sub programs until I can find my lazy space!
I had a boss many years ago who told me, "I only hire lazy programmers." I asked why and he replied, "because if I keep asking them to do the same thing they eventually give me a script and tell my to f-ing run it myself."
Same thing applies here...
« Reply #11 on: June 13, 2022, 02:37:25 PM »
You have a machine with Mach4 on it OEM?
You can upgrade it.  You will have to copy all of your configuration stuff and put it into the new version of Mach4.  '
Make a copy of everything and store it for safekeeping.
I make templates for most things here at work.  Mostly I make parametric models in Fusion and then let operators adjust the parameters; but I do make templates for G Code as well using # Variables.
Chad Byrd
