Hello Guest it is October 25, 2026, 04:02:50 AM
Author Topic: Annoying issue with my cnc router  (Read 22725 times)
« on: June 11, 2022, 09:36:31 AM »
Good Day All,
Sorry If this is in thr wrong section.
I have a home built CNC router running mach 3. Was built in 2011.
Long story short.... Left machine running a finishing pass on some vacuum forming molds came back once finished and the spindle was sitting very randomly spinning in a none natrul way. https://youtube.com/shorts/OUIfTT_EAKI
Parts I have changed thus far....
A new pmdx 126 and 107 board have been fitted.
If any one can shed any light onto this i will be greatful as you all know, Its an expesive table if its not cutting.
Thank you in advance
regards Tom
Re: Annoying issue with my cnc router
« Reply #1 on: June 29, 2022, 04:42:20 AM »
 What make is your VFD? if its a HaunYang then you might try resetting to factory settings  and reset everything.
Regards
Charlie M.
« Reply #2 on: June 29, 2022, 10:48:04 PM »
rather than just scatter gun new parts here and there you might try some things to narrow the field down.
For instance disconnect the VFD from Mach altogether and use a 9V battery to apply an analog voltage that would ordinarily be supplied by Mach and your BoB.
That would at least confirm if the VFD and/or motor are OK.
