Hello Guest it is November 11, 2026, 08:04:32 PM
Author Topic: Motor tuning settings  (Read 23419 times)
« on: June 02, 2022, 01:22:49 AM »
I'm new to March3, have used GRBL shield on Arduino before on a home built CNC machine.
Now I'm trying to set up my machine using a USB March3 controller card under Windows 7.
My lead screw have 4 start, one revolution is 8mm, diameter is 8mm.
My motors are (23HS7628) Nema23, 19 kg-cm (267 oz-in), drivers DM542S (microsteps is set to 800)
Mainly Cutting birch plywood.
Anyone who could suggest motor tuning settings for my setup ?
I have calibrated my machine with 100 steps pr. mm for all the axis.
Offline ZASto
  •  434 434
Re: Motor tuning settings
« Reply #1 on: June 04, 2022, 01:16:25 AM »
Use th same settings that you had in GRBL
My personality is who I am.
« Reply #2 on: June 05, 2022, 11:39:27 PM »
Thanks, I will try that and see how it goes.
