Hello Guest it is November 18, 2026, 11:51:38 PM
Author Topic: Subroutine Library in Mach3  (Read 17126 times)
Offline rcaffin
  •  1,073 1,073
« on: May 29, 2022, 05:46:27 AM »
Has anyone tried to implement an external subroutine library with Mach3?
It would have to be invoked via something like m98 (-c:\dir\filename), and the actual subroutine in the library addressed by a passed variable along the lines of m98 p##1.
I believe it is theoretically possible, but I know the stack space in Mach3 is a shade limited.
Roger
Re: Subroutine Library in Mach3
« Reply #1 on: May 31, 2022, 08:18:59 PM »
HIYA Roger, You can do that now with mach3. You call the sub from a remote directory with M98.
I will have to look up the details but it should be in the manual.
« Reply #2 on: May 31, 2022, 08:52:00 PM »
Put your Sub program into the subprograms folder then Call the sub with
Sub name = testsub.tap
M98 (testsub.tap) L1
Offline rcaffin
  •  1,073 1,073
« Reply #3 on: May 31, 2022, 08:59:03 PM »
Oh yes, you can do that all right.
What I wanted to do was to load the whole library in with an m98 and to then call individual routines from within the library. I doubt that Mach3 can handle that.
But there is a way if the 'library' you call in starts with another call: m98 p##1, using #1 as the vector.
Devious. But I have done it a few times.
I have also implemented an array that way.
Hum - I wonder whether a sub in the called-in file can call back to the original program? I was able to do that with the stock overlay handler on a 16 bit machine, but one did have to be careful. What fun!
Offline rcaffin
  •  1,073 1,073
« Reply #4 on: May 31, 2022, 09:01:05 PM »
The sub does not have to be in the subroutine folder. It can be anywhere if you call it thus:
m98 (-c:\dir\file)
Roger
