Hello Guest it is October 21, 2026, 05:05:02 AM
Author Topic: Relay Issues  (Read 25806 times)
Relay Issues
« on: May 27, 2022, 10:32:44 PM »
Utilizing Mach 3 on a cnc router. I setup a stand-alone 5-volt relay to run a 24-volt pneumatic solenoid for an air blast. I originally utilized Output 8 for controlling the relay. Initially for some strange reason, the relay was controlled off/on by the Reset button. I changed to a different Output and the issue went away and now relay works correctly.
I’m setting up another separate relay (same as first relay) and I’m having the same issue. I changed to a different Output and the Reset button triggers the relay off/ on again. I hope this is enough information for help.
Any thoughts on things I could check out?
Re: Relay Issues
« Reply #1 on: May 28, 2022, 08:17:46 AM »
How do you want to control the relay?
Re: Relay Issues
« Reply #2 on: May 28, 2022, 08:47:06 AM »
I will control the output signal via a macro. For the time being, I'm attempting to control through Flood or Mist command.
Re: Relay Issues
« Reply #3 on: May 28, 2022, 11:52:01 AM »
So have you set up the relay outputs in Config/Ports&Pins/Spindle Setup?  Then assign outputs to pins in the Output Signals tab?
