Hello Guest it is October 24, 2026, 08:43:30 PM
Author Topic: Z axis problem - Fusion 360 to mach4  (Read 11721 times)
« on: May 23, 2022, 02:45:29 PM »
Having issues with toolpath after post process and importing into mach 4, z axis decides to go down before x and y move to start point of cut - which looks to be the same depth. The actual 2d pocket function seems to be working correctly, just the move to the start position?
Hopefully something easy to sort - cheers ! Pic attached
Rob
Re: Z axis problem - Fusion 360 to mach4
« Reply #1 on: May 24, 2022, 01:03:02 AM »
Here's a screen shot of the g code file in mach4
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: May 24, 2022, 06:20:34 AM »
That is a post issue in fusion, try using a different post, fanuc 6 mill may be better, there may also be an option on the post config screen to change the rapid move to xy then z
« Reply #3 on: May 24, 2022, 07:44:10 AM »
Thanks Graham, I'll give that a go
« Reply #4 on: May 24, 2022, 08:26:23 PM »
Iv'e been using Fusion for two years with the Autodesk supplied Mach4 Post and I have not had issues like that.
Can you expand a little further and excerpt the Gcode that is at fault?
