Hello
Guest
it is
November 18, 2026, 11:15:30 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Mach 4 appear to be using rapid feed rate or max. speed instead of G code
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 4 appear to be using rapid feed rate or max. speed instead of G code (Read 9707 times)
NOUSE94
6
on:
May 21, 2022, 01:26:14 PM »
feed rate
Logged
stevehuck
425
Re: Mach 4 appear to be using rapid feed rate or max. speed instead of G code
Reply #1 on:
May 21, 2022, 03:53:38 PM »
How about you post your code so it can be inspected for possible problems.
Logged
NOUSE94
6
Reply #2 on:
May 21, 2022, 06:25:21 PM »
which code?
Logged
JohnHaine
975
Reply #3 on:
May 22, 2022, 05:49:00 AM »
You will need to provide more information about your problem. Under what circumstances is the speed not what you expect? Are you running a gcode program, and if so please post it.
Logged
NOUSE94
6
Reply #4 on:
May 22, 2022, 04:50:12 PM »
N10 G90
N15 G70
G50
F75.
M3
G4 P0.5
G1 X13 Y0
M5
M30
Logged
JohnHaine
975
Reply #5 on:
May 23, 2022, 12:58:34 AM »
You could try writing
G01 X13 Y0 F75
for the 7th line.
Logged
Print
Pages:
1
Go Up
« previous
next »
