Hello
Guest
it is
November 13, 2026, 02:10:29 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Anti-Backlash Nut Setting
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Anti-Backlash Nut Setting (Read 25232 times)
kolias
1,165
on:
May 21, 2022, 01:23:57 PM »
In front of the shafts double bearing there is an anti-backlash nut with a set screw.
How do I set this nut and tight the set screw. Some say this nut is not needed on these screws.
Logged
Nicolas
kolias
1,165
Re: Anti-Backlash Nut Setting
Reply #1 on:
May 21, 2022, 01:31:39 PM »
oopps... forgot the picture, somehow I select the file with the picture, file name shows in the attach, but it doesnt download the file. File is only 129KB, Sorry
Now the file shows
Logged
Nicolas
joeaverage
7,663
Reply #2 on:
May 21, 2022, 06:11:46 PM »
in theory the two bearings should be a matched pair of angular contact bearings. They are ground such that when the two bearings are clamped together tightly the correct
amount of preload is applied...it does not require adjustment by torquing the clamping nut.
Given the battle you've already had with machining tolerances is questionable whether the manufacturer used a matched pair of bearings.
If the bearings are matched there should be no increase in rotational drag no matter how tight you tighten the nut. Is this the case?
Logged
kolias
1,165
Reply #3 on:
May 21, 2022, 06:59:32 PM »
Well Craig I will take my chance and say that’s the case. I will hand tight the nut against the bearing and tight the set screw.
Despite the “machining tolerances” we talked before the Chinese vendor I buy my stuff has been very good in the past years and actually in another cnc forum members have said they are very happy with him.
Last Edit: May 22, 2022, 12:51:40 PM by Graham Waterworth
Logged
Nicolas
Print
Pages:
1
Go Up
« previous
next »
