Hello Guest it is November 13, 2026, 04:35:11 PM
Author Topic: Mach4 Lathe with Pokeys57cnc using rotary axis for toolchanger  (Read 21142 times)
Hi All,
I have upgraded a Denford ORAC lathe to work with a Pokeys57cnc card and Mach4. All the basics are running very well. Then I also would like to use an A axis for a rotary 6-station tool-changer. In principle that works as well but the rotary tool-changer has a ratchet-lock and can thus only move from one tool-station position to the next in one direction (say clock-wise).
Then inside my M6 or T macro: Say the current tool is 2 and the next tool is 1 it should move clockwise (360-60)deg to get to position 1 but the mathematics wants to move from position 2 to position 1 using the shortest path, that being anti-clockwise.
Any ideas how I can force it to only move in one direction would be highly appreciated.
Kind regards
Danie
Re: Mach4 Lathe with Pokeys57cnc using rotary axis for toolchanger
« Reply #1 on: November 21, 2022, 05:07:33 AM »
i have Luxturn lathe with 8 tools. Toolchange only in one direction allowed.
I have M6 Macro i can send you. You need to set rotary Axis as C not A.
Greetings from Germany
Daniel
