Hello Guest it is October 24, 2026, 08:42:01 PM
Author Topic: Post processor Fusion 360 for Mach4 Turn  (Read 9927 times)
Offline Oli81
  •  25 25
« on: May 19, 2022, 02:49:11 AM »
Hello There
Maybe someone can help me.
After converting my lathe to CNC with ESS and Mach4, I'm trying to find a post processor who runs reliably and is working with Fusion 360 and Mach4.
Found some articles online and some PP that are creating a G-Code from Fusion 360 and can be loaded in Mach4 but not one is working, instead of doing the job like in the simulation of Fusion 360, Mach4 do some strange things >:(
Anybody who knows a reliable PP for Mach4 and Fusion 360 or another way to bring my lathe G-Code from Fusion 360 to Mach4?
Lookging forward for your reply.
Oli
Offline Stuart
  •  311 311
Re: Post processor Fusion 360 for Mach4 Turn
« Reply #1 on: May 19, 2022, 08:19:10 AM »
https://cam.autodesk.com/hsmposts?
search vendor for artsoft    hope that sorts you out
Offline Oli81
  •  25 25
« Reply #2 on: May 19, 2022, 08:22:45 AM »
O thanks.:) Found one but this one gives me this message after trying pp a file.
« Last Edit: May 19, 2022, 08:35:05 AM by Oli81 »
Offline Stuart
  •  311 311
« Reply #3 on: May 19, 2022, 08:45:57 AM »
try posting on the fusion forum try are very helpful with post problems
Offline Oli81
  •  25 25
« Reply #4 on: May 19, 2022, 08:54:17 AM »
Did that allready thx.:)
« Reply #5 on: June 01, 2022, 10:00:29 AM »
I have used the stock PP from Autodesk with Mach4 turning without issue.
Things to check are the tool orientation and your WCS.  Make sure they all match how your machine is set up.
Chad Byrd
