Hello Guest it is October 24, 2026, 08:39:08 PM
Author Topic: Set Z button does nothing  (Read 21451 times)
« on: May 17, 2022, 10:44:47 AM »
I just tried using the SET Z funtion, under Gage Block Height, but the Z DRO doesn't change. The message in the History window shows that I've changed the Z Offset, but it never shows up in the DRO. I'm running the 7766 board, and the MAch4_Integra_Mill sample profile, and the wx4_VSI.set Screen. If anyone has an idea what is causing this, I'd appreciate the feedback. The Set Tool button works as expected, and the machine runs fine otherwise.
Cheers.
